3 comments
the bend looks fine.
Disconnect the cable at the calliper and push the cable forward and grab the pear nipple inside the lever itself, you should be able to slide the cable back and forward with ease, if that works fine, pull the cable back into place and pull on the calliper end and work the brake lever....this should give an idea of where the problem is
Checked ferrules and the rear caliper opens wide when the cable is disconnected, however there feels like there is a fair bit of resistance in the rear cable section. Does it look right?
There may be clues here ..... you say the cables are new? It's possible your cable was not installed properly, perhaps inside the brake lever housing. Is the outer cable ferrule seated correctly?
Also, when you remove the calliper the brake seems to activate properly? It could be that the mounting bolt is over-tightened, causing the calliper to bind and hence the noise you hear.
Best of luck.
